donewithtruckin's avatar
Mar 06, 2017
Not sure [Tires again]
Unable to find out rating on my aluminum rims, 235/80/16. Putting on G rated tires that require 110 lbs air! There must be a code, because there's no numbers! Thanks
  • Yup, mine was stamped as outlined above and had to have tire removed to decipher max psi rating of rim/wheel.
    Often times the load info is stamped =inside= the rim, usually in the "valley". Means you have to break down a tire to find it.
    Lyle
