mrw8i
Jul 05, 2017Explorer
I'd repair it myself - at least the first try. I had to repair my water tank when it developed a tiny crack. The tank was designed with a ledge on 2 of the sides so that it could rest on a supports. Over time it developed a hole from the movement and banging (probably when the tank was empty) while driving. I used a heat gun (it gets soft quickly, so don't over heat it) and some pieces of poly (strips cut out from an empty clorox bottle) which I placed over the hole (crack) and melted into the tank. I then put eternabond along both ledges (as a padding when resting on the supports).
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
