Wannabetravelin's avatar
Jul 18, 2014
Number of axles and hitch weight
When buying a fifth wheel does the number of axles make a difference on the weight on the hitch. Two fifths same size, same weight, will the one with two axles have a higher hitch weight than one with three axles? Looking at a 04 36RE3 Mobile Suites with a title weight of 13,360 three axles. Can a 2000 F350 LB Crew single axle tow it, more importantly stop it?
  • I agree, but you made a comment about stopping. It is a common misconception that the tow vehicle stops the trailer. The trailer brakes stop the 5er. More axles with brakes should equal more stopping power assuming every axle has brakes.
    My answer is based on I have a 07 36SB3 Mobile Suites. It weighs about 19k with 4,500# pin weight.
    U sure it has 3 axles? Really does not matter you will be WAY OVERLOADED.
    As far as stopping the trailer is supposed to stop its self.
    Bigger truck or smaller RV.
    You can't go by the 13,360 weight. My unloaded weight says 14.5K look at my weight compared to that.
  • If it has three axles and I am assuming the title weight of 13360 is dry weight then once you start loading that is going to be a lot heavier. I have a 02 F-350 dually v-10 and I only have a two axle trailer with a dry weight of 11960 and a gvw of 14000 and my trailer weighs in at 13400 loaded and my book rates my truck at 13500 max trailer weight and I am too close for comfort, it does ok but I would not want to go any heavier. Just my 2 cents worth.. good luck
  • "One size don't fit all" here but yes the triaxle trailers usually can have a bit lighter pin weight.
    "And generally speaking" its not as suspect to gaining pin weight as a tandem axle trailer when its loaded. All depends on axle placement.
    I assume you have the V10 gasser or the 7.3 diesel. The small 5.4 gasser is way under powered at those weights.
    Your '00 F350 SRW shows to have a 6830 RAWR/tire ratings thats going to carry 99 percent if not all of the pin wight of a 13360 GVWR trailer. We can only guess at the trailers actual pin weight but using 20 percent your looking at a 2600 lb pin weight. Now add a hitch/gear and folks and your in the 3000-3200 lbs area.
    The truck rear axle may weigh in the 3000 lb range which leaves the truck a 3800 lb payload. The one ton SRW shouldn't have any issues carrying that kind of pin weight.
    Fords '00 towing specs shows a 20000 lb GCWR and up to a 13900 lb trailer for the F350 SRW.
    The '00 will have a big load but take it easy and enjoy the ride.
