rcpd34
Mar 13, 2014Explorer
Odd Onan issue
I have an Onan 5500 that has always started easily and run fine. Has about 240 hrs. I have a guy doing some inside work today so I showed him how to start it and turn the heat on as it was cold. He ...
fly-boy wrote:
My money is on the carb- I suggest you buy a new carb and just switch it out- the carb is not that expensive and it is really easy to replace. You could try cleaning it but I have had mixed results-
The fact the gennie is running under a load with no problem almost guarantees you it is the carb- there is a 0.9% chance it is something else. :)
