icodeintx's avatar
icodeintx
Odd Part
Greetings everyone. I have a 2006 Rockwood 8283 SS and I'm doing major renovations. In the process of tearing out the floors I managed to cut-out (destroy) a part I now badly need. Sadly I don't even know what to call this part. Worse, I don't know where to find such parts. This is where I need your assistance. :)
This part is the hard black plastic piece that the slide sits on and uses for a ramp to go up into the body. Before I destroyed the part it used to come up into the RV and was screwed down on a piece of carpet. Sadly I cut the entire lip off that angled down through the bottom.
Here is the part along the bottom screwed into the body. You can see it runs the entire length of the slide.
https://photos.app.goo.gl/akcSxqfrPcaWDR6B6
Here is the piece screwed in from the inside before I cut it off.
https://photos.app.goo.gl/h5HKwWBEsZCZBPgYA
I live in my RV so I'm trying to make it nice. Just made this one big mistake and now need to figure out where I can purchase a replacement.
Any will be greatly apprecitated!
Scott
  • I replaced those plastic runners on my slides because mine had broken. Your local RV place should have them in stock.
  • icodeintx wrote:
    Now why don't the images work when I try to insert them :@
    Rv.net has established a particular site that the pics have to be hosted at in order to post in our threads.
  • Whatever it is, it is pretty thick and very hard. I can't bend it with my hand.
  • bukhrn's avatar
    bukhrn
    Explorer III
    sounds like a neoprene slide, can't see your pics, try to re-post them, or at least a link to them.
  • Thank you, I will check. I don't know why my images aren't showing up in the forum.
