Old-Biscuit
Jul 22, 2016Explorer III
klr650goldwing wrote:
Fridge works! Thanks guys. I'm repeatedly amazed how helpful this website is for all of us. That sensor must have been the answer because it is all I changed.
Actually......
That sensor (thermistor) hanging down (not in clip on fin) would cause fridge to cool continuously...meaning it would not cycle on/off.
That thermistor is the temp sensor for the thermostat which controls the 'heat' source to cool fridge.
Freezer section gets cooled first and releases heat into coolant which then doesn't have much absorption capability for food section to release heat to.
After freezer section starts cooling down more heat absorption is available to absorb heat from food section.
This cooling process takes several hours.....
You finally waited long enough to see affects of cooling in food section.
That thermistor should be in clip with just the tip protruding out top of clip.
If Dometic Brand it goes on far right fin...mid position.
If you have 'no temp adjustments' on upper panel (Auto Temp Control) you can affect food section temp by 4*-6*F by moving it:
UP...cooler
DOWN...less cooler
(IF you have temp controls just leave it mid position)
If you have a Norcold Brand.....clip/thermistor goes on 10th fin from right mid position.
Here is a Dometic (no temp adjustments....slide clip Up/Down)
About Fifth Wheel Group
