Aridon wrote:
My issue with the on board propane models is they really don't last long. When we boondock we stay for 6-10 hours with the genset running more or less the entire time. That would get me about a day on the miniscule propane tanks most rigs (even larger ones) come with. Sorry but I'm not filling my tanks every day or even every other day. If you boon dock so little that isn't an issue then you likely don't need to drop 5k+ on a built in to begin with.
We are getting ready to order a DRV and we are skipping gensets this time. Going to go the Honda route, bolt them down and run them from the trucks tank. Seems an inexpensive option and more flexible to boot.
I agree lp gensets are less efficient than gas.
My rig has a 80 lbs propane capacity. On board is all about convenience. 80lbs will last on most of my 3-4 day boondocking adventures.
On board will always be more expensive and more convenient than portables. No gas cans, no set up, no additional cables or wiring. Just push a button and you have full 50 amp electric.
There are no security issues. The genset is with the fiver at all times.
If the truck goes into town the genset can remain with the fiver without security worries.
I don't boondock for long periods but I like the convenience of push button power. My rig can be totally self contained when necessary.
When we stop for lunch we have A/C and microwave available. If we overnight during the summer we have A/C available. Nothing to set up breakdown or fill.
I had a set up similar to the one I posted above. I had a Subaru 4300is inverter genset mounted on a rear platform on my prior TT.
The 4300is set up was a nice compromise between true on board and portable,however that setup was not inexpensive nor was it quite as convenient as a true onboard
There are lots of camping styles,genset options,budget, and expectations. In the end there is no one size fits all solution.
