We_B_Broke's avatar
We_B_Broke
Onan generator and gauge
Sorry this will be a dumb question, My first Toy Hauler 2015 Keystone Raptor 412 TS. I put 15 gallons gas in tank labeled generator but the gauge inside does not read anything, the gauge outside at fueling area does not read anything, still reads empty shows its a 30 gallon tank,rig is level. what am I missing.
  • the gauge is bad have the same trailer it should start to move after the first 5 gallons is put in
  • on mine you have to push a momentary contact rocker switch to make the gauge move.
  • you could check the connection points (back of switch and sending unit on tank)
    if everything all tight then one of 3 things
    - broken wire
    - bad gauge
    - bad sending unit
    if it were me; i'd add it to the list of fixes for the warranty claim to happen after you get a few trips under your belt; i'm guessing you'll find some other surprises along the way
  • Gauges are lit up, I turned switch on that works the pump for fueling,Also turned off all power and ran generator gauge still reading empty.It worked when wife first picked it up and put fuel in it,has'nt worked since, only had it 3 weeks.I;ll check anything.
  • Do you have a switch which "power's on" the fuel system; does that run the gauge as well?
    Can you tell if the gauges have power? Are they backlit?
    on my cyclone the timer switch only lights up the fuel pump; the gauge for the genset is always active; but maybe yours is different
  • Mine was broken when I first got it (and it's still a little funky) but at the factory, they reversed the wires. Check that....
