mudrat025's avatar
mudrat025
onan overhaul
hello,
i have a 2004 Blaze'n toy hauler.it has a 4000watt whisper(yeah right,thing sounds like a jet plane)quiet on board generator. my question is how do you get this thing out to service it?i mean everything is buried to where you can not gt to it.....carb,fuel filter.i want to rebuild the carb and delete the origianl filter so i can put an inline in for easier install.anyone pulled one out before?
Mod Edit: Adjusted photo width to conform with forum guidelines. Please set photo width to a maximum of 800 pixels wide, 640 is ideal. Anything wider skews the forum making it hard to read on some smaller screens.
  • You might hit up Google and plug in Onan Microquiet 4000 in the video section. There are some good videos that might help you out. I found one that might help, click here
  • Some of the generators go out through the door, but others drop down through the floor. As posted, you will need to disconnect the following prior to removal:
    1. Heavier battery start DC cables
    2. Lighter status and remote start cables
    3. Heavier AC output cables
    4. Fuel line from tank or fuel pump
    5. Exhaust header and muffler
  • Brute strength and patience. I had a similar set up in my fist TH. Pulled it out twice. You should be able to pull the carb without removing the unit.
    Four bolts held it to the trailer frame. You will need to remove the 12v battery cables up front. Depending on the builder you either have a RV 30 amp plug, hardwire to a junction box on the frame or unit for the 120v side.
    I used a HD shop cart/warehouse cart to move mine around. A strong friend and a hand truck will work.
