asherdasher63 wrote:
The lines are unthawed but it says my Grey tank is full I went outside its open but frozen. Any ideas how to undo that? I filled my sink with hot water hoping it will melt it down. No its not 4 seasons that I know of but the underbelly is enclosed.
Get a new sewer hose if the existing is froze solid. Then put heat on the RV waste pipes.
You need to get access to the pipes and get some heat on them.
If you will be doing this frequently I recommend
www.ultraheat.com tank and pipe heaters as needed.
That heater under the RV... did you run that all night? Tonight you will. Do not run the water overnight again.
If you have access to the waste pipes you could wrap with some self regulating heat tape. Need to wrap with insulation also.
If no good access to the sink supply lines you could install a hot water circulating system.
Or just head South already ;)
