ToddD's avatar
ToddD
One last gooseneck question...
Done my homework, Reese Goose Box is the only Lippert approved gooseneck box for a 5er using their chassis. It is a complete box replacement, not an adapter.
My truck already has a goose ball. I'm comfortable with gooseneck hookups. I also like the articulation a gooseneck gives for uneven terrain.
I've never had issues with the ride of a gooseneck, even with my fully loaded 40' enclosed race trailer.
I don't already own a fifth wheel receiver. So money will have to be spent either way, but the Goose Box will leave my bed empty when not being used.
So any reason I am missing on why NOT to do a Reese Goose Box?
My new rig will be a 41' Jayco 5er with a 16,500 GVWR.
  • garyp4951 wrote:
    I wish they made a Goose Box to fit mine, but I called, and they don't.
    I'm tired of using a hoist every time I go rving.
    Leave it connected to 5th wheel king pin and use 5vr landing gear to raise/lower out of /into truck bed
    OP.......
  • I wish they made a Goose Box to fit mine, but I called, and they don't.
    While you are comfortable with hooking up a gooseneck, an elevated hitch like any standard fifth wheel hitch or the Andersen makes it just so much easier. Until you try a standard hitch you won't really know the difference. Also, extra articulation with a ball hookup only works when you have plenty of clearance between the truck box and the underside of the trailer. Typically clearance is less with a fiver than a GN trailer, that is why fifth wheel hitches have limited side pivot. Better to stress truck and trailer suspension and frame than repair body damage to both.
    But the warranty issue is a real consideration, so you should also consider the B&W Companion hitch.
  • brianpearce wrote:
    You could research an Andersen Ultimate 5th wheel hitch.
    Oh, I like that hitch, too, and personally don't think it would cause any issues with the frame, since the leverage point is so similar to the fifth wheel box, but if I ever had a chassis issue while using the Andersen, Lippert would deny my claim. I have that in writing.
    Maybe if I were out of warranty I'd consider it, but I am looking to buy a new 5er.
  • rhagfo's avatar
    rhagfo
    Explorer III
    I think the GooseBox would be a great fit for you.
