Lantley
Feb 11, 2015Nomad
mtofell1 wrote:
The 347RES floor plan looks outstanding. It looks like an extremely well laid out trailer. I particularly like the W/D hookups which seem so rare for some reason in mid-size fivers.
What I'm really anxious to learn is an actual weight from an owner. The 11,000 dry weight sounds good but I know there is some variation in how manufactures come up with that. Is it going to be 12K rolling down the road (SRW capable) or 14K (getting into DRW territory)?
Here's a link to a dealer in TX with one and there are 154 pictures. It's the best look I've found:
http://www.rvtrader.com/listing/2015-Open-Range-Roamer-347RES-113699741
Something I haven't found but am curious about is with the residential fridge option is there an inverter? Don't you need one?
That dry weight is based on no options. If you add lots of options like a 2nd A/C, washer dryer,on board genset you will add to the dry weight figure. This is true of all manufactures.
OR units are often 1000-1500 # lighter than the competitions comparable units due to there cable slide system which allows for lighter beams.
About Fifth Wheel Group
