- mapsExplorer
jamieline wrote:
Decided not to go with either one.
Go with something else or are you not going to purchase at this time? - VulcaneerExplorerI had a 2011 Open Range 393RLS. Nothing but TROUBLE from day 1 til the day I traded it. Cannot recommend OR to anyone. Nicely appointed, but TERRIBLE build quality.
- Jack_Diane_FreeExplorerHave had an Open Range Roamer since early 2011 with no problems with the cable slides. I like that all the mechanism and motors are inside the trailer on top of the slide.
2112 wrote:
Does Open Range still use the cable slides?
I wasn't 100% comfortable with the cables.
The Open Range fifth wheel models we looked at a month ago ALL had cable driven slides . . They sales guy swears buy them... Funny , that's because that's what he IS selling ! :B- 3_dog_nightsExplorerI vote for the Open Range, but then I already did.
- Dog_FolksExplorer II
We are contemplating the very same issue. The wife likes the Roamer, and it's interior. I like the Eagle and available running gear options. Personally, I would be happy with either.
So please keep the posts coming.
Every one helps. - jamielineExplorerDecided not to go with either one.
- spadoctorExplorer IILCI manufactures frames for OR and Jayco to their design. The majority of LCI frame issues come from manufactures that use a standard LCI frmae and build a unit to the frame specs. Montana was famous for that. As for which one....I toured both factories and from what I saw would buy the Jayco. Also never liked the cable slides....POS when introduced in the 80's and still not as reliable.
rattleNsmoke wrote:
That's interesting...but I sincerely doubt Lippert would run a separate assembly line for Jayco when all other MAJOR customers would have to their noted sub standard workmanship.
Despite your beliefs Jayco is a major manufacturer of Rv. In their brochures they claim: "Jayco builds on custom-sized frames, designed specifically for each floorplan." But who knows they could be lying.
There are plenty of posts in various message boards documenting weld and frame failures. It's horrifying. I'm not doubting that you may have read or heard something around a campfire, but I'm sure we would all be interested in seeing it documented in an LCI or Jayco brochure
Sure, I have seen the reports of frame failures, but NOT in the last 4-5 model years. Old news.
If you want any further documentation, Goggle is your friend, go for it. - bmet2000ExplorerWe have had both and currently have the Roamer travel trailer. While it does have the cable slides, it has not given us any problems. Our Eagle had an intermittent working motor on the bunk house.
I will say that the Roamer appears to be better insulated as the air barely runs compared to our Eagle.
I wouldn't hesitate to get either one and would probably go with the one that has the preferable floor plan.
About Fifth Wheel Group
