pa_bell
Oct 08, 2014Explorer
We just bought the MXT303 in August. We really likes the layout with both sides of the bed accessible without crawling over one and other.
HOWEVER, on our first extended trip (4,200 miles) the fresh water had severe leak where I had to shut off the water until needed. That was repaired in Pocatello, Idaho by a KZ dealer but after heading back we realized the water pump would not pull the fresh water from the tank.
Then the black water tank has a bad valve so the solids cannot be drained but leaks out the rest so that when you take off the cap.....YECH!!
The satellite and local cable TV outlets on the outside were reversed so we did without TV until the Idaho dealer recognized the problem.
The weather stripping around the 2 push out windows is all coming off.
When the utilities were run through the cupboards, it looks like the holes were drilled with a 3 lb. hammer.
Now, it's back to the dealer in Ohio to get this all fixed. Glad it's not the middle of summer.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
