ralphnjoann
Aug 22, 2016Explorer
TXiceman wrote:
The Andersen hitch is NOTHING like the Goose Neck adapters or the Reese Goose Ball.
The additional stress on the pin box area is negligible compared to the G/N adapter.
The folks I have seen using the Andersen hitch are happy with them and report no problems. The negative on the Anderson set up is you have an attachment attached to where you normally have a 5th wheel pin. The shops are generally not set up to handle this when it is in for service. Same issue with a G/N adapter.
Ken
I can't speak to the G/N adapter, but the Andersen adapter can be removed in ten minutes or less. Not much of an issue if you need service.
About Fifth Wheel Group
