offtohavasu
Sep 08, 2014Explorer
BigBlockTank wrote:
I have a 08 Chevy 2500HD diesel, and I know that when the trailer is plugged in to the truck plug, you have to have the tow/haul button pushed on the end of the shifter. Otherwise, the charge wire in the 7 round plug isn't working.
something has to be wired wrong on your truck. The constant power for the "charge wire" is wired direct to a lug on the fuse block. This has to be done when the truck is new. GM just tapes it up under the master cylinder. If you're not getting power unless tow/haul mode is, something is definitely wrong with your truck.
And I have a lot of experience with Duramax trucks from 06 - 14.
About Fifth Wheel Group
