Coach-man wrote:
Mile High wrote:
Ours came with a factory LED-LCD on the outside. It flips down from inside the basement to view through the cargo door. Our bracket is from Lippert (LCI) I believe. They have many varieties of brackets that work on outside TVs,
That is an excellant idea! I imagine that you would not lose any storage space in the basement by having the tv swing dowm? Thank you for the idea!!!
Yes, the basements are so tall anymore, nothing seems to bother the TV flipped up. The only issue we have had is I bump it loading lawn chairs and scratch it. I just ordered an outdoor TV cover that I'll pull over it before I start loading stuff to go home.
The bracket has a gas strut that makes it as easy as a nudge to have it retract up if you need to grab anything in the basement. I flip it up even when it is on, then pull it back down after I finish in the basement.
