beaudin12's avatar
beaudin12
Oven size
Is there any reason outside of the obvious of the opening being a different size on why you can or cannot replace a 17" oven with a 21" oven. Many of the 5th wheels we have looked at to purchase have the smaller oven. We would like to replace that with the larger oven even if it means loosing a drawer or storage space under the oven.
  • harold1946 wrote:
    Old-Biscuit wrote:
    routemaster wrote:
    http://www.lowes.com/pd_410954-481-BAK100BP_4294715790%2B4294796428__?productId=3822879&Ns=p_product_qty_sales_dollar|1&pl=1¤tURL=%3FNs%3Dp_product_qty_sales_dollar%7C1&facetInfo=Black
    Check out Lowes.
    CLICKY
    Small free standing have been used before.......will need to check LP regulator flow rating. Might need to go bigger to met additional oven/range demands
    That is no a full size range. Standard residential ranges are 32".
    The only thing that beeds to be done to operate on LP is rejetting.
    Didn't say/suggest it was a full size.
    But it does have Four 9100 BTU burners
    Typical RV range has 2 6000 Btu burners and just 1 9100 Btu burner.
    So it would be prudent to 'check' LP regulator flow rating....it MAY have to be replaced.
    Just a heads up on what might need to be changed....
  • Old-Biscuit wrote:
    Check out Lowes.
    CLICKY
    Check out Lowes.
    CLICKY
  • Wow, thanks for the Lowes tip, I hadn't thought about going that way. Cooking and baking are my passion and the little ovens just don't cut it.
  • Its all up to the coach manufacturer. We have a residential 4 burner stove and full sized oven and residential refrigerator. Both came as standard equipment.
  • http://www.lowes.com/pd_410954-481-BAK100BP_4294715790%2B4294796428__?productId=3822879&Ns=p_product_qty_sales_dollar|1&pl=1&currentURL=%3FNs%3Dp_product_qty_sales_dollar%7C1&facetInfo=Black
    Check out Lowes.
  • I would like to have the option of ordering a 30" residential sized stove with a full sized oven. Why not? You can get a residential refrigerator, why not a stove?
