ramgunner
Jun 30, 2015Explorer
1L243 wrote:
Thanks for the offer he has a manual I have looked through it. Very confusing system. I think it's a car deck that is being used in a RV with multiple speakers (inside and outside plus large base unit) I adjusted the equalizer setup but could not get the outside speakers to drop off. I imagine once you get it set the way you want it you will probably never mess with it again.
For my Rig, I wired it for Sat. I have a Sat out on the back of my receiver I use that for TV in the garage and outside TV of my toy hauler.
The outside sat jack for outside TV, I should be able just to run that coax over to his Rig (of course he will have to watch what I am watching) and plug it into his outside cable, switch his tv connection to Satellite and put tv on channel 3..Should work...But... It doesn't... Works fine over at my Rig....
On most newer RV's there are two separate splitters, one for the satellite connection which is designed to take the sat antenna to sat tuner box link (input from sat antenna) and has a frequency-appropriate splitter, and the cable link which has a different frequency-appropriate splitter. That's the RF one. Most likely the sat side isn't passing the rf signal coming from the output of your sat tuner.
Hook your output up to his cable side, make sure his tv is plugged into that, and set for chan 3. Make sure his TV is set for antenna and it should see your signal.
About Fifth Wheel Group
