hmknightnc
Aug 01, 2013Explorer
Did the entire wire get hot or just at the general location of the converter connection? If it is just at the converter then that connection is loose/corroded (take it apart, clean it, and put back together securely)
If it is the entire wire then you are drawing more current than the wire should carry. In other words the wire is under sized for the combined load of everything. Replace it with much larger wire.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
