Lantley wrote:
Curb your enthusiasm. Be prepared to play hardball.
Thoroughly inspect everything. Don't let them rush you.
Every latch ,switch, outlet ,lock,valve door hatch, latch, window, system. Check it all. If you find a problem later consider it your fault!
I dunno about this. Is everyone's dealer really that bad that they won't fix the stuff you notice when you start using the unit?
I've only bought one trailer, so I don't have alot of experiences to draw upon, but our initial walk through (yes, I had a PDI inspection checklist from someone on here and we were videoing the whole thing) was primarily orientation on how the dang thing works.
I've seen someone say 'make em let ya spend the night in it in the lot before you take it home' the above post says look at every last detail including testing every outlet, every latch, every everything. Why?
Are dealers not fixing problems that aren't noticed before the rig leaves the lot?
