Tdavid
Feb 01, 2018Explorer
Pickup rental?
I've got a challenge on my hands. I want to get my non-com Class A license in PA, but my current pickup has a max GCWR of 23,500lbs. From what I've learned you need to take the test in a rig combo tha...
valhalla360 wrote:
Do they go off of actual weight or rated weight?
valhalla360 wrote:
Also you list two GCVWR figures. Which one is correct?
- my current pickup has a max GCWR of 23,500lbs
- my GCWR would be 28,150 as per the stickers.
valhalla360 wrote:
Where did you get your info? I get that just showing up and being wrong may be a hassle but if it's off the web site, maybe try calling and explaining your situation. They may say it's not a problem or they may have alternatives you could try.
valhalla360 wrote:
You might try one of the truck rental companies (Penskie or the like). Does the licensee specially call out 5th wheel? If you had a big moving van with sufficent rating would that do the trick?
