- stro1965Explorer
B-rad Lee wrote:
stro1965 wrote:
B-rad Lee wrote:
stro1965 wrote:
Congrats B-rad Lee! Mine is currently in the shop getting some minor stuff repaired under warranty (to be expected I guess). I'll have to wait for a new gas tank fuel gauge and a new universal remote to be ordered from Keystone though.
One of the things I had them check was the black tank gauge. I couldn't get it off "full" no matter how long I rinsed. Turns out it was wired backwards (?) and full actually meant empty! Another issue I found was the garage heat strip not working, wasn't wired correctly from the factory, and the sound bar wouldn't work with the TV. Again, not wired properly from the factory. Little stuff though. Definitely 1st World problems!
Hi stro1965, Did you get your garage heat strip working yet? I tried ours and I don't think it's working either.
Yes, it works now. It wasn't correctly wired from the factory. That said, it helps but I wouldn't count on it in a blizzard! Kinda weak but better than nothing.
Hi stro1965, do you know if it was wired wrong at the thermostat or at the AC unit.
I believe it was wired incorrectly at the A/C unit. - B-rad_LeeExplorer
Hi stro1965, do you know if it was wired wrong at the thermostat or at the AC unit. - B-rad_LeeExplorer
Here is our new trailer.
- stro1965Explorer
Yes, it works now. It wasn't correctly wired from the factory. That said, it helps but I wouldn't count on it in a blizzard! Kinda weak but better than nothing. - B-rad_LeeExplorer
Hi stro1965, Did you get your garage heat strip working yet? I tried ours and I don't think it's working either. - stro1965Explorer
Chain_dogg wrote:
taken wrote:
stro1965 wrote:
Issues to be addressed that I've noticed thus far...
Slight leak at base of toilet.
Universal remote won't operate main awning.
One window binding slightly.
Gas gauge for toys gas tank doesn't work.
All little stuff. Not too shabby!
Right, completely normal. Give some use before bringing it in for these. You will find more and it will save you a second trip to the dealer...
Gas gauge probably won't show fuel till it's half full before it starts to go up, common problem with no fix.
Actually they tested it and said the sending unit was bad and another one has been ordered from Keystone. - Chain_doggExplorer
Gas gauge probably won't show fuel till it's half full before it starts to go up, common problem with no fix. - trail-explorerExplorerThat's a sweeeeeeet looking TH. Congrats!!
- B-rad_LeeExplorer
Can't wait to take mine out on it's first shake down run but I did find out that they mixed up stickers for the fuel station and generator.... At first I thought they mixed up the wiring on the gauges. :h - stro1965ExplorerHey B-rad Lee...let me save you some frustration. The antenna booster button is in a cabinet about the bed!
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 17, 2026
