Brandon327's avatar
Brandon327
Pin box hitting bed rail
My pin box has a cover on it. The other day the cover hit the bed rail on level ground. I have 5.5" clearence between the camper and bed rails. The truck is a 09 gmc sb cc 4x4. Any ideas what to do. I removed the cover and that gave me a little extra clearance. What else can I do?
  • Brandon327 wrote:
    The part that is going to hit is not adjustable. It is the mounting tabs or plates were the pinbox bolts go through. I thought about raising the hitch but then I will probably be noise high on the 5er.
    It won't be nose high if you also lower the pin box on the trailer.
  • The part that is going to hit is not adjustable. It is the mounting tabs or plates were the pinbox bolts go through. I thought about raising the hitch but then I will probably be noise high on the 5er.
  • I would recommend raising the hitch and lowering the pin box., each by one hole. This should give you the additional height you need for the pin box but not change the level of the fiver.
