For those of you that have a pin box with an air bag, do you pressurize after hooking up to the PSI you like and then release the air before unhooking or do you just leave it pumped up to the PSI you ...
I've had the AirRide pinbox for almost a year now leave it inflated all the time. I've found it's a little trickier to unhitch mine compared to a standard pinbox because of the pin's angle when it's inflated. Perhaps if you start with the trailer a little lower so that it can ride up onto the saddle(?) a bit. JK
