For those of you that have a pin box with an air bag, do you pressurize after hooking up to the PSI you like and then release the air before unhooking or do you just leave it pumped up to the PSI you ...
I too have the B&W Patriot along w/ the 5th AirBourne pin box. I, like others, air it up and don't touch it for rest of season except to top off once in awhile. Like others as well, I make sure there is some weight going onto the B&W (doesn't need to be a lot) when hooking up and never have had a problem. When unhooking, I raise the 5th just so it comes off the B&W, release handle and pull away.
