RobWNY
Aug 15, 2020Explorer
Pin Box with Air
For those of you that have a pin box with an air bag, do you pressurize after hooking up to the PSI you like and then release the air before unhooking or do you just leave it pumped up to the PSI you ...
C Schomer wrote:
I have the same thing as the OP and by the time the pin is into the hitch far enough to close the jaws, the plates are pressed together, parallel. This summer I started plugging in the cord while hitching and unhitching and manually holding the trailer brakes, so not to slide the rv off the leveling blocks and that makes jaw closing very positive and no worries about pressure in the hitch bag. 80 psi keeps my hitch plates horizontal, traveling. Craig
