Checking the rv after traveling from NM to WA I find that one of the pins that hold the ladder to the frame outside has broken. How it happened I don't know. Any suggestions on replacement?
As a quick fix find a Tractor Supply, they have a wall of part that include many different sorts of pins. May not look the same but you should find something that will work. You'll need the diameter and length of the old pin.
