Picking up our new fifth wheel on Saturday. First time fifth wheel owners. I was wondering when adding weight to the fifth wheel does this also add weight to the pin? I assume it will. Is there a way ...
I heard a number once that 60% of the weight you put in the basement will go to the pin as a general rule. If you have a rear kitchen or toy hauler, that might tend to lighten the pin. Location of the water heater and tanks also factor in. I have a Dually so I don't worry about it. If you are on the ragged edge regarding your weights, then it is best to have it weighed.
