Rwake901
Mar 19, 2019Explorer
Pin Weight
Picking up our new fifth wheel on Saturday. First time fifth wheel owners. I was wondering when adding weight to the fifth wheel does this also add weight to the pin? I assume it will. Is there a way ...
kaydeejay wrote:Rwake901 wrote:Whoa, are you saying your pin will be 3-400# over your payload? Have you figured in the weight of your hitch, passengers and other stuff?
Looks like I will probably be 3 to 4 hundred pounds over my max cargo weight on my pin then for the truck I’m buying. Guess I’ll be putting some overloads on it.
What truck are you buying? Not sure where the 15K trailer GVW came from but you are into 1-ton or even dually country.
If it's a new truck you might want to ask your dealer what overloading will do to your warranty!
