Rwake901
Mar 19, 2019Explorer
Pin Weight
Picking up our new fifth wheel on Saturday. First time fifth wheel owners. I was wondering when adding weight to the fifth wheel does this also add weight to the pin? I assume it will. Is there a way ...
rhagfo wrote:azdryheat wrote:
OP wants to know how to calculate changes to pin weight. I suggest looking up Weight and Balance in the world of airplanes as that is something every pilot needs to learn and would give the OP the answers to additions of weight.
While weight balance on a plane may help one understand tandem axles are not a true fulcrum. The axles and spring assembly will not teeter totter any weight near the axle assembly will go on the axles, with little effect on pin weight. Once to the area above the pin, then almost 100% goes on the axle.
