Rwake901
Mar 19, 2019Explorer
Pin Weight
Picking up our new fifth wheel on Saturday. First time fifth wheel owners. I was wondering when adding weight to the fifth wheel does this also add weight to the pin? I assume it will. Is there a way ...
Rwake901 wrote:rhagfo wrote:
Rwake, you still have not given much info on your Truck.
Gas or diesel?
Rear end ratio?
2019 Chevrolet 2500HD. 6.0 gas 410 rear end. Chevrolet specs that you can pull a fifth wheel up to 14200. I will not go over that. The only thing I was concerned about was cargo weight. Although I will probably be pushing the limit I’m hoping to be ok on that too. Like I said I have easy access to scales so I can check my weight. Thanks
