SH's avatar
SH
Pinbox Flex
Is there a figure used for "acceptable" pin box flex? Doesn't seem like with the amounts of weight involved there could be zero flex. Anyone know of a tolerance figure (e.g. 3/8, 1/2 etc.)?
  • Learjet wrote:
    SH wrote:
    ckwizard777 wrote:
    As far as I am concerned zero flex is the only answer.
    That would be ideal but highly unlikely!
    And not good...just like airplane wings flex...look it up. :)
    My old Sunnybrook I never visualy noticed pin flex, Same with my Montana that I have now I can not visualy detect movement while im going down the road and I really try to look for it while goin over bumps so in my mind if I can see it it's too much.
  • On my Cameo I really don't notice any. I have a Mor Ride pin box. I know the rubber in the box flexes some but not much when hooking up. I've had problem with too much flex with a Lippert frame, and had to have repairs.
  • I measured the flex on our new Mobile Suite and it was 3/8 to 7/16 and Lippard maintained that to be the norm. I suppose with 3500 lbs. or so of pin weight maybe that's why. In 20,000 miles nothing has changed.
    Not sure what the norm is but as look back through my rear view mirror, I can see the top gap between the pinbox and the trailer flex 1/4' - 3/8". I do have the extended pinbox which probably does flex more.
  • The question had nothing to do with my rig! Just wondering!
  • You failed to mention how much flex you are experiencing. Given the age of your rig, I would remove the lower cover surrounding your pin box and check for stress cracks in the frame. Move it up and down and put it under load, either with a forklift or just lowering onto your hitch.
  • When I questioned NUWA about pin box flex answer was 1/4" to 3/8" normal depending on pin box length
