IdaD
Aug 03, 2018Explorer
I guess the first question I'd ask is do you intend to put 5,720 lbs of cargo in it? Even if you did I personally wouldn't worry about it with my truck (2015 version of yours). FWIW your payload rating doesn't mean anything because it's simply a result of your heavy truck applied to a class max 10k lb GVWR. Your 6/6.5k axle ratings are the key numbers to follow.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
