kaydeejay
May 20, 2015Explorer
Me Again wrote:Chances of a failure in the cord itself that causes more than 30A but less than 50A to flow is so low it is almost zero. In the unlikely event a short occurs, then the 50A breaker will take care of it.
Just remember that you will have a 50 breaker feeding #10 30amp rated cable, so if you have a problem ahead of the trailers 30 main breaker, you could have an electrical fire risk. Chris
IMHO that "risk" is more than offset by the reduced potential of an overheated 30A outlet on the pedestal caused by dirty or weak contacts.
I use a 50A to 30A dog-bone whenever a 50A outlet is available. It's usually in MUCH better shape than the 30A ones.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
