kaydeejay
May 20, 2015Explorer
Water-Bug wrote:Not to mention the table lamps with 18 or 20g wire pulling maybe 1 amp out of those 15amp outlets. What if that skinny wire develops a fault?Roadpilot wrote:Even worse, that 20 amp circuit is probably terminated with a bunch of 15 amp sockets. If that socket doesn't have a horizontal slot on the neutral side, it is probably only rated at 15 amps.Me Again wrote:I've got a little usb box that charges my phone plugged into a 20 amp outet in the kitchen. The cable to my phone is 22 guage. Should I be worried?
Just remember that you will have a 50 breaker feeding #10 30amp rated cable, so if you have a problem ahead of the trailers 30 main breaker, you could have an electrical fire risk. Chris
Same difference AFAIC!
To the OP, get the 50A to 30A dog-bone, use it and don't worry.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
