Coach-man
May 21, 2015Explorer
The 50 amp service is over what you need for your 30 amp rig, one it should be more stable, two at 50 amps even if it is overloaded from too many other 50 amp rigs in the park you should have no problems with using 30 amps! The adaptor is less than $20, well worth the price! No worries you can not use more than the 30 amps that your rig is rated for! If there should be a fault your 30 amp circuit breaker will kick in and handle the emergency, and that would be a problem un related to your using the 50 amp plug!! The lack of knowledge about how electricity works makes you wonder???
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
