full_mosey
May 23, 2015Explorer
Coach-man wrote:
Well which is it? Are they the same or differant? I double checked my calculations online with NEC, and stand by their minimum requirements, none the less you have already contradicted yourself, the lack of knowledge about how electricity works makes you wonder!
The purpose of a circuit breaker is to protect the wire/circuit downstream by breaking the circuit.
If you plug a 100A device into a 20A socket, the wire/circuit between the breaker and the device will be protected because the breaker will trip.
Now, on the instream side of the breaker you could have 2Ga wire where that wire is protected upstream by a breaker designed to protect much higher Amps.
HTH;
John
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
