Coach-man
Jun 06, 2015Explorer
But if CSA did their job there would be an actual device that you plug into the four wire 240 volt 50 amp plug that would provide you with the 30 amp protection that everyone is trying to make you beleive is a matter of life or death! And how can you protect that device, which is rated at 30 amps from a possible problem between it and the 50 amp circuit breaker, (as pointed out that is "upstream" and you are not protected! Therefore there is nothing that will protect you, therefore the dog bone adaptors are inheartly dangerous and should not be sold or used anywhere!!!
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 31, 2026
