Sounds like it would work. A few things I would look at is: is the door in the right area to allow you to get the rear wheel in there? Also I would make sure you can back it in far enough so that the tire isn't parked on the track for the door. Then I would put a piece of carpet soft side down under the back tire. I do that with my quads. I don't have a garage so they are parked inside and started to leave rubber marks on the floor. I would also do something to keep the slider open so it wouldn't shift while traveling (maybe a 1x1 piece of board laid down in the track). Lastly make sure you tie it down good.
