Dave_Pete's avatar
Dave_Pete
Explorer II
Jul 14, 2022
Portable Hitches
I'm new to fifth wheel applications. We're looking into one, but want to keep truck bed access for our truck camper at other times.
What are my options for removable fifthwheel or lay flat types of hitches?
I'm unsure of the pros and cons for a gooseneck hitch or a fifth wheel.
We're into a 26-32' likely length with a trailer GVWR of around 7-13K lbs. I suppose that has a bearing on types of hitches to use.
Truck is a 2006 Dodge Heavy 2500 with the Cummins diesel.
Thanks.
  • Lippert will not warranty any frame damage from any single point hitch other than the Reese Goosebox. Example: Andersen, PullRite, etc.
    I went from a PullRite 2600 to a Reese Goosebox and it is a great ride with zero bucking.
    Since you don't have a factory gooseneck ball you will need to get one installed. Your choice but, be sure it is rated high enough for any 5th you may get in the future. B&W Turnover ball is popular.
    EDIT ADD: Lippert will not warranty any single point (gooseneck ball) but the Reese Goosebox because they own Reese.
