Ol_coot's avatar
Ol_coot
Possible Axle Upgrade
Noticed the other day my right front tire was wearing on outside edge on my 5th wheel. Pretty good wear. None of the others show any wear like this. Stopped by the local RV repair shop I've been dealing with for all my repairs and trust. Explained to him what I saw and he indicates it is probably a bent spindle and it would require replacing axle. I hit a pretty bad rut in Yellowstone this past summer is when I feel I may have bent it.
After all that, my question to all, since these axles are going on 6 years with around 45K+ on them and needing to change out one. I was considering just upgrading both and going to heavier weight carrying axle.
Any thoughts on benefits of upgrading or just stay with same ones I've been using and had no issues with other than bad roads and my driving.
  • You would need to know what your axle weight actually is. You do not want axles that are overkill. Too heavy duty akles will cause a harsh ride, possibly causing other problems. All that being said, I personally, would err on the heavy side.
  • When it comes to axles, bigger is better. I don't think it costs much more to go up a step or two. My two cents.
    RTer
