Likes_to_tow
Feb 12, 2017Nomad
csamayfield55 wrote:bucky wrote:
You do realize that the tube is just a tube, and only the drum rotates?
Has nothing to do with that, take 8 feet of wire and try and use it like a jump rope. This is what happens going down the road. That wire bounces around inside the tube.
While this is true I don't lend much to this explanation on this problem. It looks more like chafing during the install to me. I have seen many many trailers that have never had this issue and that goes for the 3 campers and multiple utility trailers I have owned.
Chris
The thin rubber grommet entering and exiting the axle tube will also wear with all the bouncing of the wire inside. Keep this in mind also. Since we do not know the condition of smoothness inside the axle I'm not comfortable with my wires in there bouncing. My friend had his trip to Yellowstone nearly ruined by this intermittant problem. He thought it was his brake controller and stopped by two different Ford dealers only to be told it was functioning properly. Had it not been for the nice fellow at the campground who suggested to remove the wire inside the axle they would have turned around at the end of the second day and returned home!! This video I have posted at the beginning of this thread and the opinions of those who have contributed look pretty darned conclusive that the wire inside bouncing could put you along side the road somewhere in the mountains.
This would especially be true on trailers with lots of miles on them.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
