Likes_to_tow's avatar
Feb 10, 2017
possible danger with wires ran inside axle to other side
This happened to a friend a few years ago and was very hard to find. It was very intermittent and without the suggestion of some experienced camper at a campground he may never have found the problem. Check out this video. I'm pulling mine out of the axle today on the new 5th wheel I just purchased. You can run small plastic conduit or water pipe to the other side rather than use them as manufactured....inside the axle.
https://www.youtube.com/watch?v=21QFaEw3NCE
  • aruba5er wrote:
    Replace wire with hydralic line and be done with it. Then you don't have to worry about a chafed wire. And then you can stop better even.
    And you'll be traveling lighter with all that green stuff gone from your wallet. :)
  • That wire is probably safer than it would be outside the axle. I'm not going to run out and rewire my brakes any time soon. And it is about as likely that they scraped that wire pulling it through at the factory, as having worn through.
    Good to know that it can happen, although fairly obvious that if you have a short, it could be inside the axle tube.
  • Replace wire with hydralic line and be done with it. Then you don't have to worry about a chafed wire. And then you can stop better even.
  • Very common and ancient problem. It can take an awfully long time to happen - my 04 still hasn't done it.
  • I wrapped multiple layers of tape around my wires where they enter/exit the axles shortly after I bought it in 2007. And I check those each year. So far no problems with wear on the wires.
  • That is a common problem, and has been for many years. I had that issue with previous FW. I could not believe how bad the wire inside the axle looked when I replaced it. Since most manufacturers are still using this method, you'd like to think they are using better wire/protected wire. Not likely, it should last through the warranty period without issue.
    Jerry
  • gbopp wrote:
    Clicky
    I wouldn't alter a new unit that is under warranty. I'm sure the manufacturer would use that as a reason to deny any related claims.
    I would agree with "gbopp" here but it is something to look at once warranty has expired.
    Also, I would think that this post would be better placed under "General RVing Issues" as it relates to all trailers. Just a thought.
    Happy Camping!
  • Clicky
  • They've been running brake wires thru the axle since electric trailer brakes were invented.
    Thanks for the video.
