nremtp143
Feb 22, 2017Explorer
DELAYED!!! I finally got someone to answer me back today after I called and left messages. When she called, she was apologetic that she had failed to tell me the unit was at the factory. As we were talking I asked if it was being worked on and her reply was, "No". She said they are running behind and that the guys assigned to this unit will not be finished with the unit they are working on now until the END OF NEXT WEEK and that my unit should be started after that. So, apparently the quickest it will be torn into is a week from this coming Monday. She did say that they had done a preliminary exam of the unit and it appears that one of three things has happened. 1- Broken weld in the nose, 2-the relief cut under the slide did not go all the way through the side wall to effectively stop the flex, or 3- that the aluminum beams in the front that sit on the steel beams were not "stuffed with wood for the bolts to adhere to when put in from the steel beams to hold them together":-arrgh I asked for a guestimate as to how long it would take and she stated that at least a week for the flex, then the interior wall and the AC units will have to be tested. This may be a several week process before the unit comes back. I was afraid of that!!!!! She stated that once the nose was removed and the problem found, the plant manager and the production manager have to examine to see if correct procedures were followed. No estimate on time received. Which brought me to the videos! I asked her had anyone seen them and she didn't even know what I was talking about. So, I explained to her the stud problem(short, shoddy welds, etc) and the videos that were taken and she stated that even she couldn't see the videos because they were YouTube, but there were people in the plant that could see them and she would make sure that happened. I gave her a list of the ones I'd sent them to. This is just adding to my disdain for this company now. I wonder why I wasn't told of the delay! I also wonder if that is why they haven't contacted me due to this delay. I told her that this would probably not sit well with my forum friends and others having the same complaint. I told her there were more and she was silent. I finally told her that this entire ordeal has been going on since July and has now been seen over 85,000 times. Again, she was silent. I know it is not her fault and I stayed pretty calm with her as I wanted to stay that way, but I'm ticked at the entire Montana department. This has gone on WAY TOO LONG! She promised to update me:-huh from now on once it makes its way to the floor. So, that is where it stands as of now.
About Fifth Wheel Group
