camp-n-family's avatar
Sep 14, 2018
Possible new fiver. Thoughts?
Considering trading in the bunkhouse for a new fiver. The kids are getting older and prefer sleeping in the tent anyways. We really like the Jayco Eagle 317RLOK. Anybody have one? Reviews seem pretty good overall. We've seen a few in person and build quality seems to be better than a lot of what we have seen.
A local dealer has several left over '18s in stock on sale for a decent price that we may look at on the weekend. They've offered good money on our trade. Looking usually gets me into trouble ;)
My biggest concern is the weight. Not looking to get into a "you should have bought a 3500" or "you'll be over payload" debate. More interested in peoples' experience with similar sized fivers.
Fiver is 10,600lbs empty with 2k pin weight. (yes, I know dry weights are meaningless) GVWR is just shy of 13k. We'll never load it to the GVWR. Using our current trailer loading I'd estimate we'd be 12k loaded with around 2500lbs on the pin. Tow vehicle is a '17 Ram 2500 Cummins crewcab. I'm not going to post the payload as it is not a limiting factor in my mind. More concerned with the axle rating. I know it will be close, if not slightly over the 2500's rating. The 2500 and 3500 use the same axle, however the 2500 is rated lower for some reason (springs?). I plan to add airbags it as I have a level lift on it so it will sit low in the rear regardless of the weight and I prefer the smoother ride. (yes, I know it doesn't change the ratings).
Anyone have similar setup that can share some insight?
  • You will be right at the trucks load limit with an empty trailer. Loaded even lightly is likely going to push you over trucks GVWR. You may or may not care about that, but then again......
  • I think you will really like a rear lounge floor plan...just one thought:
    Have them put all the slides in and see it you can access different areas and feature or are you cut off...make sure you can get to the frig, pantry, and things like that for a quick stop lunch while on the road without deploying the slides.....(if that is important to you). Does appear that the bathroom won't be a problem.
