cummins2014
May 10, 2015Explorer
Jerry B wrote:
While driving my 1998 Chevy Dually yesterday, the engine died. I wqas left with no brakes and steering was next to nothing. Got it off the road and found that the positive side terminal on the battery was corroded inside the cable boot so there was no power at all in the truck. Now, if I had been towing my 18K 5th wheel down hill when this happened I would have been toast since the brake pedal could not have sent a braking command to the 5th. This has me concerned that a simple thing like a corroded battery terminal can about do me in. I will definitely make sure my serpentine belt is like new, battery terminals are clean and all power cables and grounds are good.
You were running off the battery until it died, apparently you don't have an alternator light or gauge that is working. Sounds like an alternator or relay went out, and you were running on the battery until it went dead. Corroded battery terminal did not do you in, it could of prevented the battery from getting a charge, but then the truck would eventually not start.
About Fifth Wheel Group
