Jerry_B
May 10, 2015Explorer
Charging voltage is about 13.2 volts. This truck flat stopped running when the battery terminal circuit opened up due to the resistive corrosion. In the old days, I too have pulled a battery out while the motor was running. Perhaps with the newer alternators, field excitation current is required from the battery. Regardless, the truck quit. I cleaned the terminals, and everything is now fine. The accumulator in the Hydraboost provided about two pumps then the pedal went to the floor. This is a single point failure that can possibly do one in.
About Fifth Wheel Group
