Sturgeon-Phish
May 11, 2015Explorer
Goostoff wrote:this is a common issue with side terminals and the bolt mod works real well. It also gives you a better place for jumper cables. I think autozone has a kit by the battery cable section
Oh the joys of owning a GM vehicle with the absolute worst battery connection system in history. Then to make them worse they put this big monstrous hunk of rubber in there so you need to be on the verge of stripping the threads out of the battery to make a good connection. There have been quite a few people make fun of my battery cables but they never ever corrode. I took all the rubber******off my cables and screwed a 3/8 bolt into the battery with a nut and washer on it to use as a jam nut. Then sprayed the **** out of it with battery cable .
About Fifth Wheel Group
