kohana's avatar
kohana
power awning failure to retract
So as evening comes on and the wind picks up your awning starts to rattle and jump. you try to retract it and nothing happens. 12v is good c/b is good now what?
  • mileshuff wrote:
    700g wrote:
    mileshuff wrote:
    Dometic had a recall on some of their awnings a couple years ago. Motor issues.
    Reading the manual on mine mentions removing a screw and rolling it up. However, doing so damages something internal and the manual states it must then be serviced.
    If you roll the awning up this way the motor will be trashed.....new motor needed
    Thats the method Dometic specifies. Haven't heard of any other way if the awning won't go up other than the usual check power, wires, breaker etc.
    When Dometic says it will need to be serviced, that translates to a new motor. When you roll the awning up this way it twists the wires to the motor and usually jerks them out of the motor housing. Ask me how I know, LOL
  • I have a Cougar that has a remote for the awning and sometimes I have to use that instead of the switch to retract the awning. Can't figure it out.
  • schlep1967 wrote:
    Go out to the end of the awning that has the motor on it. Have the other half push the button while you listen for the motor to run. On mine the motor was running but the end cap had stripped out. If that is the case you should be able to jam a piece of wood in there to make it roll up.
    I fixed a neighbors with the problem you told about. Poor desigh or cheap metal on in the end cap. I drove a brass rod I flatten to fill the space at the flat area of the cap and motor shaft. Yes it was going to be windy so time was important. A pin though the motor shaft and the end cap would solve this issue.
    chevman
